Resolutions
Streams from X.IO support the following resolutions:
Minimum: 16 pixels wide by 16 pixels tall
Maximum: 1920 pixels wide by 1080 pixels tall
We support any even-numbered resolution inside the above parameters. If you request an odd-sized height or width value, we round down to the nearest allowed even number.
For example, a resolution of 1000 by 801 would become 1000 by 800, and a resolution of 2000 by 1000 would become 1920 by 1000.
Frame Rates
X.IO will vary the frame rate delivered to the client depending on it's capabilities and available network bandwidth, however we always try to maintain a minimum of 30 frame per second.
Using our browser-based client, the maximum allowable frame rate is 30 FPS.
Comments
0 comments
Article is closed for comments.
