Requirements
- OctaneRender License - If you do not have a license, you can purchase it on our shop page
- Cinema 4D Host Application - Maxon Cinema 4D host application. Please note Cinema 4D should be updated to the latest version as a minimum in order to run the Cinema 4D plugin. For example, you should be on at least, R25.117, R26.107, 2023.2, 2024.4, 2025.0.1, 2026.0.0. To update Cinema4D to the latest version, navigate to the top menu bar, click Help > Check for updates or download and install the update from your MyMaxon/Downloads page.
- Hardware - NVIDIA graphics card
- OctaneBench (optional) - You can test your GPU with OctaneRender by installing OctaneBench. OctaneBench® allows you to benchmark your GPU using OctaneRender.
Installation
OctaneRender for Cinema4D provides an installer and archive version. Further down the page, you will find the instructions for the archive version.
Installer
1. Launch the installer after downloading from your OTOY account.
2. Click Next when the setup prompt appears:
3. On the following page, click Next to agree to the License Agreements.
4. Select the Cinema4D version(s) you want to install the OctaneRender plugin for:
You can check the box "Automatically remove manually installed plugins" if you have existing manually installed Octane for C4D plugins you want to remove.
5. Click Finish to close the installer.
6. Make sure you've updated your Cinema4D version to the latest version.
Archive Installation
1. Download the OctaneRender plugin from the Downloads page of your OTOY account and extract the content of the archive. Add the content to the plugins folder in Cinema 4D file system. We recommend using 7-zip as some utilities can encounter issues decompressing the folder.
2. The OctaneRender (i.e. OctaneRender_2024_1_2) folder will come with several versions of the plugin in it. In order to avoid any loading issues, delete all of the c4dOctane-R(version number).cdl64files that you will not be using. For example, if you are using R2025, you would delete the c4dOctane files that are not c4dOctane-R2025.xdl64. You should not delete the other files (res, Lib300)
3. Maxon Cinema 4D does not include a plugins folder. You will need to create this folder in the Cinema 4D R2023 folder: C:\Program Files > MAXON Cinema4D 2023 > plugins (you need to create this folder!) > c4doctane
Important note: The "plugins" folder should be lower-case. The folder is case-sensitive so you may encounter issues if the plugins folder isn't lower-case.
4. Launch the Cinema 4D application. You will be prompted to enter your OTOY account credentials.
Once you have entered your credentials, you should see an Octane tab at the top of your application.
Now you should have successfully installed the OctaneRender for Cinema 4D plugin.
Troubleshooting
If you launch Cinema4D and the startup is stuck on "Initializing"...
- Check your c4doctane folder to confirm you've deleted the RXX files that do not match the Cinema4D version you are using.
You can see Octane in the menu but you can't click it or you don't see Octane in the menu
- Check to see if Cinema4D is the latest version, click Help > Check for Updates in the C4D menu.
If you get a CUDA 700 render error..
- Check to see if your NVIDIA driver is updated. Next, check to see if your OS is updated.
If you get an Internet port error..
- Confirm that the firewall allows both Cinema4D and OctaneRender as the plugin utilizes both connections.
If you continue to have issues, you can write our support team at help@otoy.com
The OctaneRender for CINEMA 4D manual can be found here.
